Re: B414 change to 2-way hydraulic loader
Posted by Bernard le mecano on June 15, 2009 at 15:26:58 from (75.158.246.207):
In Reply to: B414 change to 2-way hydraulic loader posted by ronb.vip on June 15, 2009 at 13:33:34:
Hi, cut the pipe that go from the pump, hitch one,weld a fitting at the cut end, run a hose, from the fitting, to the IN of the loader valve.On the pipe, that go in the hitch valve, weld a fitting too, run a hose from the OUT of the loader valve, to the fitting weld on the pipe to the hitch. The best place to cut, is under the fuel tank.Now you can run the loader and the hitch without turning knobs. Bernard le mecano Quebec Canada
