Re: F-14 brakes
Posted by Darwin Schossow on June 15, 2009 at 15:43:53 from (70.58.220.73):
In Reply to: F-14 brakes posted by MartyG on June 15, 2009 at 11:30:26:
third party image
third party image
I have seen the brakes so frozen, that after getting the drums off, I still had to break the shoes to get them off. You can start by flooding the drum with penetrating oil and letting it soak a while. Try to make sure the brake actuating rod is in the flat position Pulling the tractor might break the shoes loose from the drums, it might also score the drums. Failing all that, you'll need to remove the wheels and the drums and take a pry bar and hammer to the shoes.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
