Re: Model 46 baler
Posted by JLE on June 15, 2009 at 16:06:15 from (173.123.131.147):
In Reply to: Model 46 baler posted by Karl Hamson on June 15, 2009 at 14:54:49:
One thing that is overlooked is the hay-dogs, they are spring loaded on the top of the chamber and the bottom, near the needle slots, if the springs are broken, will not hold materal back and the materal will deflect the string causing the twine disc to miss said string. Timing also important. Also make sure the twine disc are in time. Some times they can be A SOB. Good luck.
Jim
