Posted by Hugh MacKay on June 15, 2009 at 18:18:53 from (209.226.106.152):
In Reply to: I'm puzzled posted by Andy in Manteca on June 15, 2009 at 12:20:03:
Andy: The others have given you the date codes, they are 1/2" high digits with day and month by number and year the others have indicated by letter. Every major casting has one, digits cast in place, and what looks like a round head, blade type screw cast between each of day, month and year.
The control box steering support extends from is exactly same on all Super A, 100, 130 and 140. The Farmall A may be a bit different.
I can't understand why you think this looks like an AV except it doesn't have 19" front tires and 36" rear tires. Is it the diamond shaped axle? That was the standard axle on a Industrial. It was also optional on every Farmall from the first A in 1939 to the last 140 in 1979. There may be differences in spindle lengths, some hi-clears used 16" tires.
If you go to engine block part number Farmall A or AV should be 6342 DH, early Super A and AV up to serial number 310300 should be 251069 R1, late Super A or AV should be 354898 R1, 100 should be 354898 R2 or R3, 130 should be 366204 R1 and 140 should be 367825 R1 or R2. Those numbers are cast in place and partially behind the oil filter. Those were factory original part numbers for each model.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
