Re: Wheel exchange
Posted by rustred on June 15, 2009 at 19:41:58 from (72.172.100.113):
In Reply to: Wheel exchange posted by Bernie Steffen on June 15, 2009 at 19:19:24:
you would need to find another set of rims and then cut them to your spec and reweld them together. this would give you only one circumference weld for each rim.so yes it can be done.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
