Posted by J.J. from Afton on June 15, 2009 at 19:57:25 from (66.41.82.17):
In Reply to: 340 HELP posted by Tracks on June 15, 2009 at 08:47:22:
I may be wrong but I do not believe that the ball is sold seperate from the axle least not from the dealers. The likely reason they didnot use a nut to hold the ball on is that over time it would wobble or rattle off. The cap holds the ball from going side to side and being pulled downward becasue the weight and movement of the tractor on the axle pushes the wishbone up and back for the most part. As for the ball I believe it is only prssed in likely when the axle is hot and expanded hence why it is not welded. So you will have to try heating around the pin to see if the ball/pin will be able to driven out or pressed out or you may have to replace the whole main piece of the front axle.
Is there any chance that you could post a picture or two of the ball/cap you're talking about?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
