Generator belt adjusting
Posted by Mike CA on June 15, 2009 at 22:57:27 from (99.28.152.102):
I got a 12v genny from an MD. I swapped the belt pulley. I also got a new generator mount because the one that came off my tractor was drilled out... I'm assuming to move the generator forward. So, with the new genny, and the new bracket, with the old pulley... It's too far back. (see first pic below, you can see the second pulley below. It's out of focus, but it should show you how the belt line is off). The pulley seems to tighten on, and that's it. I don't see a way to adjust it out farther.
The only adjustment I see is the bolt and screw that allow you to adjust the width of the rear pulley guide. (see second pic)
So, I'm clueless on how to get this thing pulled forward. I'm assuming the two pulleys are supposed to be completly in line?
third party image
third party image
