Posted by Rootsy on June 16, 2009 at 09:04:54 from (24.247.111.162):
In Reply to: gm diesel posted by tugger on June 15, 2009 at 19:18:12:
The 2-71 came in a "kit". You did the install yourself and you had to do some of your own parts acquisition and fabrication. My father has an M with an original "kit". Has the proper engine (GM block), proper bellhousing, flywheel and variable speed governor as well as the other parts listed in the parts list. I have the original install instructions somewhere that verifies this tractor has the original "kit" per P/N match and not some back alley garage cluster... Currently in the process of cleaning up the original installation and doing a restoration on the rest. hopefully finished in time to make the trip across the Big Mac this fall...
There are a couple of 2-71 equipped M's floating around that are retrofits. A couple are very well done.
Original "Kitted" M's are about as rare as hens teeth...
There is also an MD with a 2-71 retrofit (not sure if it is an original GM kit or not) in Cheboygan. They do quite a bit of pulling with it...
Here is ours as purchased.
This post was edited by Rootsy at 09:13:08 06/16/09 3 times.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
