Farmall C ground cable
Posted by andy r on June 16, 2009 at 14:37:09 from (67.224.8.75):
Putting together a Farmall C that had been modified over the years. The 6 volt battery goes into the tight fitting box in front of the steering column and the box for the amp and temp gauges. In fact the battery box provides the back side of the gauge box. Of course this is positive ground. The cable for the starter goes from the negative to the starter out of a notch in the top front right of the battery box.
MY QUESTION IS????? Where does the ground cable go from the positive terminal???? Does it stay in the top of the battery box under the lid and ground to one of the two bolts connecting the battery box to the gauge/steering column?? Or does it leave the battery box and ground somewhere else.
Thank you for your assistance. andy
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
