Re: Electrical on Farmall H
Posted by El Toro on June 16, 2009 at 16:48:22 from (205.188.116.73):
In Reply to: Electrical on Farmall H posted by Pat B in Mich on June 16, 2009 at 15:15:20:
Take a volt meter and measure the charging voltage across the battery terminals with the engine at 3/4 throttle. Your coil has nothing to do with the lights being dim if you're talking about the ignition coil. If you're only getting
7.2 volts to your battery, that isn't enough to charge your battery. You should be using 00 battery cables and make sure all connections are clean and shiny. That includes where your battery is grounded. Hal
