Undo the coupler (ujoint) on the steering rod and then take the end out of the steering shaft (big nut looking object on the steering gear round box) and wind the shaft out of the gear box and consequently radiator, Dont forget the two nuts that old the radiator to the chassis on the bottom. Henry I ended up cutting the studs off and welding new ones on later.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
