Re: H shifter repair
Posted by SDE on June 16, 2009 at 20:13:50 from (174.124.13.51):
In Reply to: H shifter repair posted by deano4863 on June 16, 2009 at 19:12:54:
I don't know the dimensions, but if you look at the shift rails you can determine a working size that will work.
SDE
