Re: tell me im not crazy
Posted by Brownie 450 on June 17, 2009 at 03:59:09 from (216.51.158.209):
In Reply to: tell me im not crazy posted by w miller on June 16, 2009 at 17:46:06:
How well does it run? If there is a crack in the cap, it theoretically could run on 1 cylinder. I know it is possible on a gas 706, because the neighbor changed the spark plugs & wires on his 706 & got the coil wire in #2 hole on the dist. cap & the #2 wire in the center hole.
