Unless the threads are stripped, the valve you have might be good to use. I say this because it looks (from the photo) that the valve has been both soldered, and brazed into the tank. The solder (silvery color) looks to be on the fitting in the tank, to the tank. The braze looks to be on the valve to fitting. If so the solder will melt first and leave the fitting on the valve. If the valve is leaking, it might be easy to have the needle (turnable part) machined in a lathe to make it new. Good luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
