Re: Gear noise in Super C
Posted by ScottyHOMEy on June 17, 2009 at 14:04:56 from (71.241.193.175):
In Reply to: Gear noise in Super C posted by thumbanger on June 17, 2009 at 13:57:57:
These are straight-cut gears so there is some inherent noise anyway. Do you notice it more in some gears than in others? Is it louder or does it change between pulling or coasting in a given gear? If the tractor was worked a lot and hard (say plowing or cultivating) in a particular gear, you can bet on it being noisier.
No popping is a good sign, but if you can describe anything else, it might help identify a serious problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
