Posted by Haas on June 17, 2009 at 19:27:48 from (12.65.66.183):
In Reply to: BN PTO/Belt-pully posted by Tom -S.Jersey on June 17, 2009 at 18:28:30:
The parts catalog CD shows two versions of the belt pulley arrangement. One has a gasket between the two housings and shims in the bearing retainers. The other shows shims between the two housings. If you did not have shims or a gasket in there, then I'd say none were required. When the shims are used, there is no gasket. The shims act as the gasket and ofter you will get a little oil seepage. Back in 1940, a little oil I suppose was considered a normal thing. I've had good luck using a very light coating of spray on gasket sealer in this situation.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
