The extension effectively makes the clutch pedal travel farther to do the same job. As a result the point at which it disengages (no longer drives the wheels)will be substantially farther from the resting position (foot off the pedal) The test: With the tractor off, and brakes locked. stand next to the clutch pedal. Put your hand on the pedal and push it down (forward). As you push the clutch pedal arm will be pulling on an external return spring. The pedal should move easily with only this spring tension for very close to an inch, to an inch and an eighth. If it continues down with little resistance it is out of adjustment (freeplay) and needs to be adjusted to the range above. If it tightens up and gets substantially harder to push at the Inch range, then the freeplay is correct. Then the issue is why it has this exaggerated range of motion. One possible answer is partially sheared pins in the throwout fork to cross shaft. Another is a warped disk that is not letting the Pressure plate release unless it is pushed in too far (less likely). M clutches are hard to push. If you need the effort reducing lever, OK adjust to work as best as possible.
You state that the point of engagement is almost at the bottom, and it is jerky (most tractor clutches are jerky and designed to be delt a starting force equal to a drag race every time it is started under load. (If it were mine I would put the standard clutch lever(shorter)on it to see if it eased the engagement issue, or made it too hard to push. I was 140 pound teen driving them in the 60s, and it was not an issue then. Let us know. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
