Re: Re: Bolt pattern and cyl. head torque specs.
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phil Auten (TX) on April 13, 2000 at 13:14:17 from (206.175.72.226):
In Reply to: Re: Bolt pattern and cyl. head torque specs. posted by Justin on April 13, 2000 at 06:37:35:
That should read "work out in a spiral pattern".
65 ft/lbs sounds correct. Be sure to work up to that in three steps, starting at about 45 ft/lbs, then 55, then 65. Retorque after running the engine for a couple of hours at operating temp and cooling down. Then again after about another 10 hours of running time. This will keep your head gasket from being blown by a bolt/nut that works itself loose. Also, lubricate the bottoms of the bolt heads and the nuts so they won't interfere with getting the proper torque.
Have fun,
Phil
Post A Followup
: Re: Re: Re: Bolt pattern and cyl. head torque specs.
