Re: 340 utility
Posted by Hugh MacKay on June 18, 2009 at 11:06:55 from (216.208.58.170):
In Reply to: 340 utility posted by mattofvinings on June 18, 2009 at 10:01:41:
Matt: Actually the only thing on that tractor similar to a C is the engine. Same block as used in tha Super C.
The rest of the tractor is basically 300, newer version of the H with IPTO, live hydraulics, TA available.
240 is the tractor that fall in the line of C, SC, 200, 230 and finally 240.
