Re: Super A mystery gauge
Posted by Hugh MacKay on June 18, 2009 at 11:17:31 from (216.208.58.170):
In Reply to: Re: Super A mystery gauge posted by Dave From Texas on June 18, 2009 at 09:14:10:
Dave: You control levers are out of adjustment. When this happens the lever is trying to make the rockshaft cylinder go beyond end of it's stroke. look on bottom of touch control unit where linkage to lever protrudes. There are stops on there need to be adjusted. With the tractor at low idle, both control levers at center. Move each lever separately and slowly to the limit, each way. If you hear the engine start to labor, the stop needs adjuting to that position and bit more. Do it both ways on each lever. When you get the stops adjusted, then you can adjust levers to suit the stops. Should eliminate the heat.
