Re: installing H 4 magneto on a TD-6 gas start diesel engine
Posted by El Toro on June 18, 2009 at 11:55:31 from (205.188.116.73):
In Reply to: Re: installing H 4 magneto on a TD-6 gas start diesel engine posted by ejensen on June 18, 2009 at 06:52:10:
The engine should start when you install the mag that way. If you ever pull a mag or distributor
again for any reason note where the rotor is pointing. Make a little sketch then DON'T move the engine. When its ready to reinstall you point the rotor by your sketch and you don't need to bring No1 piston to TDC on the compression stroke. Your tractor should start. Hal
