Re: Generator charging questions update II stumped
Posted by JMOR on June 18, 2009 at 20:29:07 from (72.181.158.237):
In Reply to: Generator charging questions update II stumped posted by Hoss in Me on June 18, 2009 at 18:42:43:
a_lead said: (quoted from post at 22:23:19 06/18/09) Teddy:
It stops charging when I remove the gnd on the field term.
Thanks Edward
The "bottom contacts" you speak of seeing pull closed when you rev the engine would be the cutout function, most likely.
The other set of contacts would be your field contacts (which should be closed at rest). Make sure those field contacts are actually making continuity.
You could even short them together with a screwdriver to see if that makes charge.
