574 trans. lube pump
Posted by ohio dick on June 19, 2009 at 09:44:54 from (4.131.41.139):
trans lube light start coming on below 1500 rpm with trans hot checked pressure had 10 psi drained oil pulled mcv. pickup screen was clean removed and disassembled pump had some wear installed new pump from IH filled with new hytran still 10 psi. is there any thing else to check.
