There should be two small disk like plugs on the left and right side of the shifter. Either drive one of these into the hole, or drill a small hole in it and put a screw into it to pull it out. There is a pivot pin inside that gets driven out the other side (pushing the other disk out of the far side.) The pin may be worn and also need replacement. The pin can be made from a grade 8 bolt shank cut to length. Good luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
