(It's still Haggis. I posted under Haggis a while back on another board and the cookie keeps defaulting -- all my tractor buddies are almost as confused as I am at this point!)
That last bit of information is important. It sounds like you might have after-market replacement rims, which will make a difference in the bolt length.
The original lugs on the rims were rectangular, riveted to the rim, and had a square recess in each side so that a square-head bolt dropped in just about flush from either side. That kept the head from turning.
The common replacement rims have a loop welded to the rim, just the right size to pass the 5/8" bolt through, but NO recess, so that the underside of the bolt head presses against the end of the lug, rahter than the center as the originals did. These are about 1-5/8" or 1-3/4" deep. Because they aren't recessed, you'll need longer bolts. 3-1/2" will work for the steel wheel and 4" on the cast. If that is the case, there's no advantage to square heads and you can use the easier to find hex heads. I don't know of any clips that fit on to hold them, just a wrench on each side.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
