Posted by Wardner on June 19, 2009 at 23:49:28 from (4.154.241.179):
In Reply to: Re: IH Hydra-Creeper posted by Wardner on June 19, 2009 at 23:05:12:
Can't seem to sleep tonight.
Rather than build a Hydra-Creeper gearbox, you can go with a cleaner solution. The expensive planetary you see below was purchased for around $75 on eBay. They come in all different ratios and HP's. I am using this 3 to 1 ratio unit to speed up the one-of-a-kind right side Electrall. They work even better as reduction units.
So you have three options here.
1. Attach a small hydraulic motor on the high speed side and then attach the complete unit to your PTO.
2. Remove one final drive and place it between the final drive and the housing it attaches to.
3. Stuff it in your torque tube.
This all pre-supposes that you have a lathe and perhaps a milling machine. Older machine tools are dirt cheap now. I have been to machine shop auctions where good old iron have received no bids. The junk man won't even bid because he cannot handle them.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
