Re: IH Hydra-Creeper
Posted by Hugh MacKay on June 20, 2009 at 03:59:50 from (216.208.58.191):
In Reply to: Re: IH Hydra-Creeper posted by mattofvinings on June 20, 2009 at 01:48:06:
Matt: How would you ever call these "stump puller gearing". Any time you apply fluid or hydraulic dirve you actually reduce torque to the rear wheels.
I'don't know what Wardner's motive is, haven't been following these threads, however hydro creeper drives and hydrostatic transmissions were not designed with maximum drawbar pull in mind. They were designed to give exceptionally slow speeds for vegetable seeding, transplanting, spraying, harvesting etc.
I just got out my Farmall 130 manual, maximum drawbar pull in 1st gear using hydro creeper drive is 1,980 lbs. A 130 in regular 1st gear would pull 3 times that amount. Believe me, I have pulled 7,000 lbs in a tractor pull. In that same hydro creeper drive IH specs do state 130 travels 24 feet per min. with no load, and 15 feet per min. at maximum load. Hardly a stump puller.
