A unit intended for use as a motor will work in both directions. A unit intended for use as a pump is intended for 1 direction operation unless it is listed as bi-rotational. In many cases a pump can be disassembled and reconfigured to the intended direction. I would contact Prince to be sure that their unit will work for your usage. I do not know how fast that you intend to operate the motor, but at speeds below 1000 rpm, gear motors and pumps loose a lot of efficiency because of leakage past the gears. An orbital motor will give better results at lower speeds.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
