Re: SMTA brakes
Posted by scot in pa on June 20, 2009 at 14:25:53 from (12.171.162.28):
In Reply to: SMTA brakes posted by 460anger on June 19, 2009 at 15:26:23:
The actuator only goes in one way. Get some high-temp, copper-based, never-seize and coat the ramps and balls. If you use it very much you can do this once a year for a LONG time and still be money ahead. The gray graphite-based stuff doesn't take the heat well, gums up, and they start to stick again after a little while.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
