In order to remove the banjo casting which is the rear axle housing you pull the two counter shafts (the long drive shafts) which are held in by the bearing retainers on the end. Each bearing retainer is held in with three bolts, when you remove the retainers the shaft may or may not come with it. Than you can remove the banjo casting in the manner the others were talking about. I had to take it all apart to replace the banjo casting and the double ball bearings that carry the ring gear.
This post was edited by J.J. from Afton at 15:44:09 06/20/09.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
