Re: Worth the weight
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phil Auten (TX) on April 13, 2000 at 15:21:48 from (206.175.72.226):
In Reply to: Worth the weight posted by Willie on April 13, 2000 at 15:13:07:
Willie,
The farmall M weights are round, 1-piece weights with an odd shaped hole in the middle. The hole looks like a diamond with the pointy ends cut off.
Should mount with 4 bolts to the cast wheel centers with the axles sticking through.
I've never seen weights for the inside of the wheels, just for the dished in side. I have seen some aftermarket weights that are a lot thicker and heavier than the factory weights and they look a lot rougher and the center holes are round. They were cast to fit the dish in the wheel center and nearly fill it.
The segmented weights might be for a Ford or an Allis, or possibly one of the later, larger Farmalls.
Phil
Post A Followup
: Re: Re: Worth the weight
