What I would look for next is what happens when you give the steering wheel a slight "crowd" in either direction with wheels fully engaged with the ground.
What I would expect is pump pressure would rise as the spool moves and forces the boost/assist cylinder to move, then as the spool re-centers, the pump pressure would then drop back to zero (open-center/spool-neutral condition).
Another mental abstraction to think about (or from the viewpoint of) is that the system doesn't exactly "demand" pressure in my thinking. In retrospect, it "creates" backpressure (what the pump-output gauge is reading) by virtue of creating an effective restriction to fluid flow or presenting the ever-adding positive-displacement volume of fluid against a mechanical load (as in the case of a hydraulic cylinder).
Just a practical example of above, with a functioning system I would fully expect pump backpressure to be significantly lower when turning the tires on a film of slick mud vs. when they are half-buried up to the axles. In other words, even though the pump can produce 1400psi when thoroughly dead-headed, the pressure is "matched" to the mechanical "resistance" load applied in the opposite direction.
This post was edited by mattofvinings at 16:41:34 06/20/09 3 times.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
