Re: Super H Carb question
Posted by Red Mist on June 20, 2009 at 17:21:55 from (67.142.130.46):
In Reply to: Super H Carb question posted by jonnny2006 on June 20, 2009 at 17:04:15:
jonnny2006 said: (quoted from post at 17:04:15 06/20/09) i took the carb off and bluw it out. same thing. i might need to soak it. what is best to use?
Carburetor cleaner. You can buy it by the gallon can or by the 5-gal. bucket. Either way - disassemble the carb and let it soak for 2-3 days. Then, rinse off parts with a water hose and blow out passages with about 150 lbs of air pressure using a good rubber tipped air nozzle. Be careful you don't shoot carb cleaner in your eye while using the air hose. Then reassemble, mount and adjust. Good luck.
mike
