Re: Radiator removal on 1948 Farmall M
Posted by Red Mist on June 20, 2009 at 17:33:54 from (67.142.130.46):
In Reply to: Radiator removal on 1948 Farmall M posted by BMD on June 16, 2009 at 16:38:48:
Allan Kropelnicki said: (quoted from post at 14:44:23 06/20/09) Those two nuts you talk about on the bottom, i cannot really see them, but i do feel a nut and a spring on each one, they are on each side of the rad, under the frame. Do they have to be unscrewed, or can it be pushed up, its hard to see there. Do i just use a socket??, small hole for a wrench, it looks offset?? Got everything else off, i hope.
Yes, they have to be unscrewed and a deep socket is best.
mike
