Re: leaking hydraulic fluid international 340
Posted by J.J. from Afton on June 20, 2009 at 17:40:44 from (66.41.82.17):
In Reply to: Re: leaking hydraulic fluid international 340 posted by billde on June 20, 2009 at 16:43:34:
The hole is there so that the center or dry section of the torque tube does not fill up with oil should one or more of the seals on the mainshaft fail. This is because the chamber is where the T/A flywheel and clutch are located should the tractor have one. Our 340 leaks out there too whenever the engine is idled down like cause the seal is worn or theres a groove in the shaft or both.
-Jordan
