Re: Farmall M Funny noise and rebuild price question
Posted by mkirsch on June 21, 2009 at 04:52:25 from (67.240.251.254):
In Reply to: Farmall M Funny noise and rebuild price question posted by tcanthonyii on June 20, 2009 at 21:49:05:
The knock could be the cam gear coming loose on the camshaft. We had that happen once, and it was a relatively easy fix, but it did require pulling the entire front end assembly off the tractor to get the front cover off.
The oil pressure is probably bearings. If the journals on the crank aren't too egg-shaped, you can get away with simply sliding new bearings in.
