Re: Farmall M Funny noise and rebuild price question
Posted by Janicholson on June 21, 2009 at 06:20:34 from (66.173.50.176):
In Reply to: Farmall M Funny noise and rebuild price question posted by tcanthonyii on June 20, 2009 at 21:49:05:
The noise might be a broken cam drive sprocket. They will crack and still work but make noise and the valve timing will be getting worse and worse. The Keyway in that gear is also suspect. Replace it with a gear from a SMTA, 400, or 450. This gear is much stronger and designed for Live pump use. The oil pressure issue might be as simple as a repair and flattening of the oil pump cover plate. They can warp allowing very low oil pressure. Easy to fix. It needs .001" to .0005" clearance. (Use shims carefully to set clearance) Clearance is determined using thin gaskets.
Sleeve and higher compression piston Kits will be in the 500 to 800$ range. Add the Coolant and hoses etc. and still less than 1000. JimN
JimN
