Re: 656 motor
Posted by ed1 on June 21, 2009 at 06:39:11 from (69.117.7.231):
In Reply to: 656 motor posted by Chubby on June 20, 2009 at 16:17:30:
I believe the 560, 6x6 series also shared some engines with the 706. My 686 used the D-312 and later oned used the D-310 German engine. At just under 70 PTO Hp the D-312 had a may RPM of 1800.
If I turned up the power and RPM to 2000 I'm sure I could have pushed the PTO HP into the low 80's.
I'd be careful about a bigger engine as your limiting factor is the amount of HP the transmission can handle.
I'd also switch to Diesel if not to to expensive.
