Posted by Janicholson on June 21, 2009 at 07:25:16 from (66.173.50.176):
In Reply to: 450 PTO posted by chris450 on June 21, 2009 at 07:08:35:
Assuming you have a band style PTO (I think they had two styles depending on Production Date.)
Simple as I can make it. Make sure the lever and linkage is free of lost motion and bad woodruff keys. Place the lever exactly mid way between the two latched positions. The PTO shaft should turn (with nothing hooked to it)by hand. Tighten the forward adjustment lock and screw until the band is tight and the shaft wont turn (by hand with good effort) Loosen it until the band is loose enough to turn freely (just enough, not 2 turns) Do the same for the rear adjuster. Now try moving the lever to the operate position. It should pull harder at the last few inches of travel, and lock in nicely. If it pulls hard enough that it seems wrong, the band is too tight. Do the same for the brake band (off). If the adjusters are almost down to level with the top of the lock nuts, there isn't much band left. Best of luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
