Re: Farmall H: Engine Stuck
Posted by Brownie 450 on June 21, 2009 at 15:33:25 from (216.51.158.178):
In Reply to: Farmall H: Engine Stuck posted by RB in PA on June 21, 2009 at 14:39:00:
When you turn the pulley, how many turns can you get? Does the engine fan only turn so far & then you turn it backwards? If you can keep turning the engine by hand, the engine is loose.
If this is the case, try shorting across the starter switch connection bolts[I've gotten in trouble before for suggesting this} & see if the starter engages & turns the engine. If it does, try replacing the starter switch.
