Some ammeters are not "damped" as well as others and the needle bounces excessively. (Think from the "Land of Almost Right".)
Alternator or generator?
Bad generator brushes/rough commutator will make the ammeter bounce, as well a worn-out or poor-quality voltage regulator.
(A certain amount of ammeter bounce is NORMAL with the old generators and "vibrating point" mech voltage regulators. The charging rate is not as steady as with the modern electronic regulators we have become used to.)
Also, a poorly grounded regulator or rubber-mounted regulator with a bad ground strop will be erratic.
If it is keeping the battery properly charged, it may be more or less a "cosmetic" problem... LOOKS worse than it is.
