Re: why does my H voltage regulator only last a couple ye...
Posted by Bob M on June 22, 2009 at 08:30:58 from (151.190.254.108):
In Reply to: why does my H voltage regulator only last a couple years? posted by Dann G on June 22, 2009 at 07:57:18:
Dann - Any idea how the regulators failing? (Burned/welded contacts, open winding or resistor, internal corrosion or ???)
I've had regulators fail on my Super H and Minnie-Mo U (both tractors use the same regulator). Both reg's are about 3 years old and have probably less than 30 hours run time between 'em. They are marked "made in USA", though not by Delco.
I originally attributed the failures to simple bad luck - but now I'm not so sure.
