Re: why does my H voltage regulator only last a couple years
Posted by Gerry....WI on June 22, 2009 at 08:46:21 from (68.117.3.48):
In Reply to: why does my H voltage regulator only last a couple years? posted by Dann G on June 22, 2009 at 07:57:18:
What is your procedure for polarizing the generator?
Is your tractor set up as postive or negarive ground?
