Does your battery polarity match the regulator polarity. A regulator should be marked "positive ground only" "negative ground only" or "works with positive or negative ground". A regulator marked positive only or negative only in a system set up the opposite way will shorten the life of regulator contacts.
You can buy a Delco alternator (early to mid 80's GM vehicle) cheaper than a regulator. Use the 3 wire set up.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
