Re: Farmall M wide front end
Posted by Andy Motteberg on June 22, 2009 at 11:10:12 from (4.143.216.118):
In Reply to: Farmall M wide front end posted by 37 chief on June 22, 2009 at 07:17:36:
My Farmall M has a IH wide front with the early style lug-type clamp rims. If you have that style also, you need the "blank" rims with NO mounting tabs riveted to the rims. If you have the later adjustable type hubs with no lugs, use the rims with the 3 riveted tabs. You need the right rims for the right hub, the two do not interchange.
