Posted by Andy Motteberg on June 22, 2009 at 11:16:22 from (4.143.216.118):
In Reply to: M Stuck Valves posted by RickAshman on June 22, 2009 at 09:19:53:
Do a compression test on those "non-firing" cylinders. With the engine cranking, check for spark at all the plug wires. Make sure the tractor has a good set of plugs. If there is spark to all the plugs and your distributor or magneto is in good working order, take off the valve cover and see if there are any stuck valves. I had a problem similar to this with my F-20 when I got it and found 3 stuck valves. I was always pouring PB Blaster and oil on top the valves, pryed them up with a large screw driver and tapped them down again. Repeat several times until the valves move freely and do not stick.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
