The gears will whine some, nature of the beast. The popping is very likely one of the big ball bearings on the diff shafts, the ones that pass out through the side of the tranny to the final drives. And it is the seal around that shaft that is leaking. If you're lucky, the popping will be on the same side as the leak. There are also large bearings and seals at the tops of the final drives around the diff shafts and another pair at the bottom around the actual axles. Removal of the diff shaft on the left of an A is much simpler than on the right, but either makes a good project. The mauals give the order of work and you can find some good threads on it here in the archives.
Also, on the popping, don't rule out a loose wheel bolt. That can get pretty noisy, too, but is usually but not always in both directions.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
