Re: Farmall M dies when you give it gas,,need help
Posted by SDE on June 22, 2009 at 15:34:11 from (174.124.13.51):
In Reply to: Farmall M dies when you give it gas,,need help posted by Jim in Michigan on June 22, 2009 at 15:25:19:
Have you checked for any air leaks around the carb to manifold and manifold to head areas?
My guess would be that the mechanical advance is stuck in the distributor or the weights in the governor are stuck. But it is just a guess.
SDE
