Re: Farmall M wide front end
Posted by David Goode on June 22, 2009 at 17:53:12 from (66.82.162.19):
In Reply to: Re: Farmall M wide front end posted by Trader George on June 22, 2009 at 17:06:08:
Thanks for the Info, didn't know that. I did see that some people had slightly diffrent hubs and this now makes sense. Thanks
-David Goode Coggon, IA
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
