Re: SA Front Mounted Ball Hitch
Posted by Hugh MacKay on June 22, 2009 at 19:03:51 from (209.226.106.188):
In Reply to: SA Front Mounted Ball Hitch posted by Doug Kieta on June 22, 2009 at 12:56:27:
Doug: I do it a lot with my snow blade push frame. All I need do is pull two pins at blade angle point and blade comes off. In fact that is all I ever take off my 130 in the summer.
I wouldn't try to move a trailer weighing more than 2,000 Lbs. and tongue weight of 300-400 lbs. Great for moving light trailers. You probably go less with a Cub.
If you don't have a snow blade, build a drop frame from the front axle cultivator mount. Then run a long bar similar idea to a swinging drawbar, from out front of tractor to the drawbar, using the drop frame to suspend it. Having said that, I WARN YOU, WATCH THE WEIGHT.
